AX Lightness Europa Seatpost
AX Lightness Europa Seatpost 31.6 mm, L1 3K$445.00  $356.00
Save: $89.00 off
 1 Remaining
AX Lightness Europa Seatpost 31.6 mm, L1 Unidirectional$475.00  $380.00
Save: $95.00 off
 1 Remaining
AX Lightness Europa Seatpost 31.6 mm, L2 Unidirectional$475.00  $380.00
Save: $95.00 off
Notify Me When Available
AX Lightness Europa Seatpost 31.6 mm, L3 3K$445.00  $356.00
Save: $89.00 off
 1 Remaining
Weight, L1100 grams
Weight, L2110 grams
Weight, L3130 grams
Available Lengths220 mm(L1), 290 mm(L2), 350 mm(L3)
Available Finishesunidirectional, 3K weave
Tube Materialcarbon fiber
Bolt Materialtitanium
L1 Adjustment Range7-14 cm
L2 Adjustment Range13-20 cm
L3 Adjustment Range19-26 cm
A/X Lightness presents the Europa, one of the lightest zero setback seatposts available. The Europa is available in three lengths (220mm, 290mm, 350mm) and two diameters (27.2, 31.6), with two different finish options (unidirectional and 3K weave). A/X utilizes carbon prepreg and Kevlar to manufacture an incredibly lightweight and strong tube structure. The clamping beams are composed of 7075 T6 series aluminum, with rolled thread M6 titanium bolts.
Ordering
Because the Europa uses a tapering wall thickness to achieve such extreme light weight, there is a limited area in which the post can be clamped for each length post. The adjustment range measurements are taken from top of the seatpost collar to the saddle rails. See this page for a sizing illustration.
We strongly recommend use of Tacx Assembly Compound to reduce the amount of torque needed to secure this seatpost.
Comment on AX Lightness Europa Seatpost
