Ashima Disc Brake Adapters
Ashima Disc Brake Adapters AU01$12.00 In Stock
Ashima Disc Brake Adapters AU02$12.00 In Stock
Weight, AU0122 grams w/bolts
Weight, AU0227 grams w/bolts
AU01 Fitfront: IS fork, PM caliper, 160mm rotor
rear: IS frame, PM caliper, 140mm rotor
AU02 Fitrear: IS frame, PM caliper, 160mm rotor
These Ashima disc brake adapters are designed to allow Post Mount (PM) calipers to attach to International Standard (IS) frame and fork tabs.
Ordering
Adapters are specific to front and rear brakes and rotor diameter. Please take care when ordering to ensure you receive the correct adapter.
Comment on Ashima Disc Brake Adapters
