Ashima Centra-Lite Centerlock Adapter
Weight, with lockring23 grams
MaterialSteel Carrier, Aluminum Plate and Pins
Details
Ashima’s Centra-Lite adapters allow the use of standard ISO six bolt rotors to be used on Shimano and DT-Swiss centerlock specific hubs. With fewer brands manufacturing centerlock rotors, this converter opens riders up to a wider, more exotic variety of six bolt rotors. Per wheel, each converter weights a mere 23 grams, the primary carrier of which is steel, while other parts are aluminum.
First, sandwich the rotor between the adapter's splined inner plate and the outer pegged plate, then attach the assembly to the hub. Once fitted to the hub's centerlock mount, a Shimano cassette lockring tool is required to properly tighten the threaded lockring. If a torque wrench is available, tighten the lockring to 40 Nm.
