Ashima Aluminum Rotor Bolt Set
Ashima Aluminum Rotor Bolt Set Black $16.00  3 Remaining
Ashima Aluminum Rotor Bolt Set Gold $16.00 In Stock
Ashima Aluminum Rotor Bolt Set Red $16.00 Notify Me When Available
Weight, Set of 6 Bolts4.8 grams
ThreadM5 x 10.5
Material7075 aluminum
Usecross country
Ashima's aluminum rotor bolts have been specially designed with the specific properties of the aluminum material in mind. Traditionally, manufacturers have produced aluminum rotor bolts using the same design as steel, yielding an insufficiently strong and unsafe product. When used as intended for light use or cross country racing, Ashima's rotor bolts are sufficiently strong enough for use on rotors up to 160 mm in diameter. The weight savings over a typical set of steel bolts is about 8 grams.
To ensure rider safety, Ashima's rotor bolts must be properly and carefully installed. We recommend prepping the bolt threads with a medium-strength loctite before installation. Initially, each bolt should be lightly fastened against the rotor. Then, using a torque wrench calibrated to 4Nm, the bolts should be tightened in an alternating pattern, as illustrated here.
Comment on Ashima Aluminum Rotor Bolt Set
