Ashima Aineon Disc Brake Rotor
Sign Up For Our Newsletter
You're Signed Up!
Material Stainless Steel
Alloy carrier
Hub compatability ISO 6 Bolt
Sizes 160mm, 180mm
Weight
180mm 88g
95g (w/ bolts)
160mm 71g
78g (w/ bolts)
Ashima Aineon Disc Brake Rotor 160 mm $59.16 Notify Me When Available
Ashima Aineon Disc Brake Rotor 180 mm $64.26 In Stock
Details
Ashima's Aineon disc brake uses the same stainless steel rotor as their popular Ai2 rotor with an alloy carrier. The alloy carrier can reduce weight (mostly noticeable on the larger rotors) but is mainly used by Ashima to better dissipate heat. The six included bolts are AL-7050 and anodized with locking washers.
Links
Comment on Ashima Aineon Disc Brake Rotor
