Ashima AI Stainless Steel Rotor
Ashima AI Stainless Steel Rotor 140, Black $30.00 In Stock
Ashima AI Stainless Steel Rotor 140, Blue $30.00 In Stock
Ashima AI Stainless Steel Rotor 140, Red $30.00 In Stock
Ashima AI Stainless Steel Rotor 140, White $30.00 In Stock
Ashima AI Stainless Steel Rotor 160, Black $30.00 In Stock
Ashima AI Stainless Steel Rotor 160, Blue $30.00  1 Remaining
Ashima AI Stainless Steel Rotor 160, Red $30.00 In Stock
Ashima AI Stainless Steel Rotor 160, White $30.00 In Stock
Ashima AI Stainless Steel Rotor 180, Black $35.00 Notify Me When Available
Ashima AI Stainless Steel Rotor 180, Blue $35.00  2 Remaining
Ashima AI Stainless Steel Rotor 180, Red $35.00 In Stock
Ashima AI Stainless Steel Rotor 180, White $35.00  1 Remaining
Ashima AI Stainless Steel Rotor 185, Black $35.00 In Stock
Ashima AI Stainless Steel Rotor 185, Red $35.00 In Stock
Ashima AI Stainless Steel Rotor 185, White $35.00 In Stock
Ashima AI Stainless Steel Rotor 203, Black $40.00 Notify Me When Available
Ashima AI Stainless Steel Rotor 203, Blue $40.00  2 Remaining
Ashima AI Stainless Steel Rotor 203, Red $40.00 Notify Me When Available
Ashima AI Stainless Steel Rotor 203, White $40.00  1 Remaining
MaterialStainless Steel
FitsISO, 6 bolt
Sizes140, 160, 180, 185, 203
Weights140-68gr, 160-85gr, 180-112gr, 185-113gr, 203-136gr
ColorsBlack, Blue, Red, White
Designed in the U.K. and manufactured by Ashima in Taiwan, the rotors are available in 140mm, 160mm, 180mm, 185mm and 203mm diameters. Ashima rotors are manufactured to be lightweight, yet durable. Other manufacturers will integrate materials such as titanium and carbon fiber into their rotor designs to save weight, at the expense of reliability, wear life and overall performance. While Ashima's rotors are manufactured from a durable variety of stainless steel designed specifically for disc brakes; the weight savings comes from aggressive (and stylistic) machining. The enlarged cut-outs in the rotor act as vents which aid in heat dissipation. The surfaces are double ground to keep both sides of the rotor completely parallel and true. No special pads are required for use with these rotors.
Comment on Ashima AI Stainless Steel Rotor
