Alligator Universal Bleed Kit
Sign Up For Our Newsletter
You're Signed Up!
Tool List
Includes
  • -1 DOT syringe, 1 Mineral oil syringe
  • -Fittings for: Avid, Formula, Gatorbrake, Hayes, Hope, Magura, and Shimano
  • -Clear tubes for syringes and fittings
  • -8mm and 10mm combo spanner wrench
Alligator Universal Bleed Kit Universal Bleed Kit $29.99 In Stock
Alligator Universal Bleed Kit Quick Bleed Fitting $8.00  1 Remaining
Details
Alligator has come out with one kit that has the ability to bleed every major kind of mineral and dot fluid brake on the market. No longer do you need multiple kits to bleed whatever kind of brake you might have in your fleet. Complete with a syringe for both DOT and mineral fluid, as well as any lever/caliper fitting you might need. We highly recommend purchasing the alligator quick bleed fitting to go with your universal bleed kit.
Quick Bleed Fitting
The quick bleed kit is a simple one way valve with two small tubes to connect to your syring. The valve helps prevent bubbles from entering your system during bleeding and making the overall process faster.
Comment on Alligator Universal Bleed Kit
