Abbey Bike Tools Dual Sided BB Socket
Sign Up For Our Newsletter
You're Signed Up!
CompatibilityShimano 9000, 6800, 5800, and current XTR
Weight120 grams
Material7075 aluminum
Driver size3/8 "
Abbey Bike Tools Dual Sided BB Socket Dual Sided BB Socket $55.00 In Stock
Details
Oregon’s own Abbey Bike Tools, manufacturer of some ingenious, must have tools for the professional or home mechanic, regularly impresses the cycling world with their excellent designs. Without exception, Fair Wheel Bikes is excited to introduce the dual sided bottom bracket socket wrench. As visually pleasing as it is mechanically functional, the dual sided socket wrench is CNC machined out of a solid billet of 7075 aluminum and hard anodized for guaranteed long service life.
While other manufacturers cast their bottom bracket sockets, Abbey Bike Tools decided that this process wasn’t accurate enough for the precision fit they desired. When as precise a fit as possible is required to make sure new parts aren’t marred upon installation, the best tool for the job is a must, and that tool is certainly the bottom bracket socket tool from Abbey Bike Tools.
Compatibility
The dual sided bottom bracket socket wrench from Abbey Bike Tools is designed to be compatible with Shimano Dura-Ace 9000, Ultegra 6800, 105 5800, and current XTR bottom bracket shell types. These shells as somewhat smaller than the traditional external bottom bracket that you may be accustomed to, so be sure to check which drivetrain you’re running before purchase.
Comment on Abbey Bike Tools Dual Sided BB Socket
